BUILT COMPUTER RAN FOR AN HOUR SHUT OFF WONT POWER UP
Hello,
BUILT A NEW COMPUTER. RAN LONG ENOUGH TO PUT WINDOWS ON IT. I LEFT IT RUNNING TO COME BACK TO FIND THE COMPUTER COMPLETELY SHUT OFF. CHECKED POWER SUPPLY WITH THE MANUFACTURERS TROUBLE SHOOTING INFO. iT WORKS dISCONECTED EACH ADD ON ONE AT A TIME. NO DICE! NO POWER WHATSOEVER! DO YOU THINK THE BOARD OR PROCESSOR WENT BAD?
15 answers Last reply
More about built computer hour shut wont power
  1. OK, post your specs...
    CPU:
    RAM: with link please.
    Motherboard:
    GPU:
    PSU:
    HDD: /SSD
    OS type + version
  2. Did u do a clean install?
  3. yes clean install
  4. Here are the specs:
    Intel Core i5-3570K 3.4GHz Quad-Core Processor
    COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
    ASRock Z77 Extreme4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    Mushkin Enhanced Blackline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model 996995
    Western Digital Caviar Black WD2002FAEX 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    OCZ Agility 4 AGT4-25SAT3-128G 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
    EVGA GeForce GTX 670 FTW 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
    COOLER MASTER CM Storm Series Trooper Black Steel / Plastic ATX Full Tower Computer Case
    CORSAIR Professional Series HX650 (CMPSU-650HX) 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
    LITE-ON 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA Blu-ray Burner with 3D Playback, LightScribe Support
    Asus VS248H-P 24.0" Monitor
    Microsoft Windows 7 Home Premium SP1 64-bit
  5. OK, can u check the switch on the back?
  6. U wrote,
    What it means?
    NO DICE!
  7. Tried the paper clip method to test it. The fan started spinning.
  8. Can u reset the BIOS?
    Reset the CMOS memory the right way as is described in the motherboard manual using the clear CMOS link with the power cord unplugged.
    And when the battery is out, press the power button to discharge all the electricity from the system.
    How To Clear CMOS @ http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
    OK, so the PSU can turn on, but we don't know if it is OK, just bu doing that : )
    Any way to try another one?
    No other machine to try it on unfortunately.
    Cleared CMOS, nothing. Still won't boot.
  12. only issue i saw was looked like your sat cable was not plugged in all the way or snaped..should be flush with the conenctor (gray one).
    with no video card and one dimm and no sound card any fan spin or numbers on the mb diag leds?? do you smell anything that could have fried?? if you have a local micro center...have them test the ps with a ps tester or pick up a new one and see if that the issue.
    Don't smell anything.
    I didn't connect a lot of things yet. The case alone had problems with the fan controller in the front. Cooler Master is sending me a new one. I just need this thing to boot up some how. The closest Microcenter is about an hour away. What type of services do they have? Can they put it together if I give them the components?
  14. each store is diffrent..call them up...some have a walk in support area at lest there you could plug in a new ps and see if the system posts. if you have a local best buys you can buy and return a ps there for testing.
ASRock Power Up Computer Power Supplies Motherboards
