I just built a new PC, this is my first custom build. The issue is that My computer runs for a period of time then proceeds to shut down, sometimes it reboots instantly and doesn't even read as a faulty shutdown (windows had a term for it). other times it just flat shuts down and doesn't reboot itself. It always starts right back up if i manually start the computer and will then run for hours at a time. Ive noticed also it doesn't ever have this problem while i'm actively using the computer this seems off to me because i've been on it for hours at a time. It's not a windows update thing either i'm pretty sure. Also all my temps appear to be pretty good 30c idle haven't gone over 44c although i haven't really done a stress test yet. The only thing that i can think of is that perhaps my UPS isn't capable of powering my 650 watt psu. But i'm not sure. i understand that this issue is pretty vague and could be caused by hundreds of things, but any suggestions would be greatly appreciated.
Specs:
Antec 900
GIGABYTE GA-970A-D3 AM3+
XFX HD-679X-ZDFC Radeon HD 6790
XFX Core Edition PRO650W ATX12V 2.2 & ESP12V 2.91
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s
XIGMATEK LOKI SD963 92mm HYPRO Bearing CPU Cooler bracket included I7 i5 775 1155 AMD
Specs:
Antec 900
