Need sound card?
Hello,
I am currently buying a gaming set up and my new bought computer has a asrock Z77 extreme 4. I was wondering if I needed a new sound card with it since I plan on buying a good pair of 2.1 speakers? Does the motherboard already has a good sound output or is a new audio card is needed? If yes, which one should I get (money is not a problem right now). Also, on a side note, which speakers would you recommend?
Thanks!
3 answers Last reply
More about need sound card
  1. Anyone?
  2. Modern onboard sound is pretty good. Unless you're very discerning/ have really good ears you shouldn't need a sound card. That said, if you do go for it the Asus sound cards are very highly rated.
  3. Imo, and I'm no audiophile, a sound card isn't needed as most motherboards have pretty good sound onboard. As for speakers, I'm using these on one of my rigs >> http://www.newegg.com/Product/Product.aspx?Item=N82E16836121036 and I'm happy with the sound they reproduce. Audiophiles may disagree with me, but hey, different strokes, for different folks.
    Hope this helps, good luck.
Motherboards Speakers Sound Cards Product
