Archived from groups: alt.games.video.nintendo.gameboy.advance (More info?)
I am having a problem in connecting Harvest Moon AWL to the GBA and
harvest moon FOMT. Whenever i try to connect simply put nothing
happens. I have tried switching on the game boy at different times,
done everything they say to do. But none of it seems to work. Any
ideas at all as to what could be the problem.
Are you using a legal copy or a rom on a flashcart? If legal, try and pull
it out, blow inside the GBA slot, blow the edge of the cartridge, and then
push it firmly into the slot. Keep it firmly pushed in with your hand, and
turn the GBA on - see what happens.
I have had similar issues with one of my GBA's, and the above seems to sort
it.
I vaguely remember that there was some sort of problem where you need
to say "yes" instead of "no", or "no" instead of "yes" in response to
a question the game asks you during the connection procedure.
