PLEASE HELP: USB 3.0 Problems!
  • ASRock
  • Device Manager
  • USB3
  • Motherboards
July 22, 2012 8:26:47 AM
OK, so I have the ASRock Fatal1ty 990FX motherboard. I am having serious troubles with USB 3.0. It used to work fine, until I reinstalled Windows. Now the USB 3.0 ports keep messing up. I reinstall the drivers and update them through device manager using the drivers disc. If I plug something into the first USB 3.0, it works fine. If I plug something into the second one, it messes up and in device manager I have a bunch of HIC USB errors or something like that. OH, and I can't use any of the USB ports after that. They don't work. And when I press the power button, the it just stays at the Shutting Down screen.
More about : usb problems
a c 329 V Motherboard
July 22, 2012 8:51:03 AM
Whats your OS?
m
l
