Hi there,
I just installed this new mother board into an existing chassis with a 700 watt power supply. When tuning on power, the onboard start/reset swiches light up along with the BIOS1_LED. Also the Go LED lights for a split second. On hitting the start button, the chassis fan starts to rotate and the power supply fan tries to rotate. Also the top GND and the ICH_PCIE of the Voltiminder LED II light for a split second. Then nothing.
The start and reset buttons stay lit but do not do anything unless I kill power or hit the CMOS reset.
I pulled out the video card and unplugged the hard drives to relieve any power drain. Again same results.
Any ideas?
Thanks,
Jeff
===============System=======================
CPU and Cooler and RAM installed by Motherboard supplier: J&N Computer Services
Intel i7 3930k socket 2011 CPU, 6-core, 3.2Ghz
GELID Solutions Tranquillo CC-TranQ-01-A 120mm
Hydro Dynamic CPU Cooler * REV. 2
Mushkin Enhanced Redline 8GB (2 x 4GB) 240-Pin
DDR3 SDRAM DDR3 1866
• Total memory installed - 32GB
GeForce GTX 680 2GB 256-bit GDDR5 PCI Express
3.0 x16 HDCP Ready SLI Support Video Card
Any ideas?
Thanks,
Jeff
