Will this computer build work well?
I'm building a computer for the first time and want to know if these parts will work well together and fit in the case.
2TB Hitachi CoolSpin 5K3000 Hard Drive
http://www.scan.co.uk/products/2tb-hitac…
Intel Core i5 2500K 3.3GHz Socket 1155 6MB Cache
http://www.ebuyer.com/251596-intel-core-…
Coolermaster Centurion 5 II with 650W GX PSU
http://www.ebuyer.com/250952-coolermaste…
G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V
http://www.ebuyer.com/264750-g-skill-8gb…
Gigabyte GA-Z68A-D3-B3 Socket 1155 7.1 Channel Audo ATX Motherboard
http://www.ebuyer.com/269125-gigabyte-ga…
I think I will use the integrated graphics but if I want to put in a graphics card later, will the power be sufficient?
Thanks.
Also, can I install windows vista 64 bit or windows 7 64 bit on it?
5 answers Last reply
More about will computer build work well
  1. If you have no plans on using this build for gaming...you could size down on your psu. Either o/s will work..vista 64 or windows 7 64. If you don't have either atm and plan on purchasing one then Windows 7 64 bit would be the obvious choice.
  2. First of all you have to change the motherboard. You can't use onboard graphics with that motherboard.
    While your stuff does fit in that case, that powersupply is pretty low quality, i suggest investing in something better.
    Get this motherboard instead: Gigabyte GA Z68A-D3H-B3 £109.36 - more expensive yes, but will do what it needs to.
    Here is a better quality antec PSU for you: Antec HCG-520 £53.58
    Memory is fine.
    HDD: Samsung Spinpoint F3 1TB £40.38
    Fast, Cheap Reliable.
    Case: well they don't have the centurions without the PSU, so maybe something else Antec 300 or something ~£50 probably anyway.
    Then get a DVD drive to install the OS with.
    And yes you can install windows 7 64 bit on it.
  3. Thank you sooo much! I took your advice and have changed the components accordingly. However would it be possible to keep the motherboard I have chosen originally and use a cheap graphics card such as:
    http://www.amazon.co.uk/VTX3D-Radeon-5450-DDR3-Graphics/dp/B004J0YBYI/ref=sr_1_5?ie=UTF8&qid=1311888635&sr=8-5
    Will this work well?
    Again, many thanks!
    Again, many thanks!
    That will work fine, or you can get this board down below and use the intetrated graphics on the cpu - HD 3000
    http://www.amazon.co.uk/Z68-PRO3-M-Micro-ATX-Motherboard-Onboard/dp/B0050GD56A £94.99 & this item Delivered FREE in the UK with Super Saver Delivery
    Asrock Z68 PRO3-M Micro-ATX Motherboard (Socket 1155, Onboard Sound and LAN)
    http://www.asrock.com/mb/overview.asp?Model=Z68%20Pro3-M <----- more on that board
    http://www.tweaktown.com/reviews/4100/asrock_z68_pro3_m_intel_z68_motherboard_review/index.html <---- review w/benchmarks on that board
  5. Thank you
New Build Computer Systems
