Am i running with 1600Mhz ram?
kersh
53
Hello
I got a question regarding my ram, i want to know if my ram are running at 1600Mhz or not, im getting 667Mhz for each slot in CPUZ, but in bios it says 1600Mhz can someone please help me out.
Please check the pictures below:
CPUZ
Here i enabled the XMP profile 1 and it automatically presets it to 1600Mhz, but there is 1300Mhz next to it i dont know why, anyone knows?
This is the first screen in the bios, where it says im running at 1600Mhz memory.
Is this normal, and am i actually running at 1600Mhz but for some reason CPUZ dosent want to show that?
Any help is appreciated.
kersh
53
It shows DRAM Frequency 807.1Mhz, so i guess it works, but why does it show 667Mhz each under the SPD tab?
timbob13
13
the 667MhZ you see under SPD is half the clock of the Double Data Rate aspect of DDR3 (667x2=~1333). You see it because DDR3 memory has a default clock setting hard-coded into the memory for compatibility, to ensure it's able to run on the system
Xeuyi
SPD is what allows the computer to detect the memory. It detects it at a fail-safe setting (in this case, 1300MHz). Or something like that. I'm sure someone else can give you a better explanation.
kersh
53
Yeah i have the latest version i believe, 1.61.2x64.. So it should actually say 800Mhz or so under the SPD tab also?
kersh
53
Okay then i guess everything is running at 1600Mhz, i just didnt understand why it said 667 Mhz under the SPD tab then.
Thanks for the help.
