Okay, I have an Asus G73jh.
It has the AMD Radeon 5870.
I have 2 monitors, the laptop monitor (primary monitor running at 16:9, 1600x900, 17.3").
And a secondary monitor that I got a couple of years back, I forget the size, it is between 19-21. But the thing that effects my situation is since it is 16:10, running at 1680x1050.
Now, I have games such as Burnout Paradise, that support multiple monitors, but, my issue is, that when I try to run games when my secondary monitor (Compaq W201q) is hooked up, the games don't play properly, they aren't distorted, but they go into a 4:3 mode, or like Burnout, it becomes 1/2 the regular size, and runs at the new aspect ratio on my laptop monitor. Basically, my laptop monitor becomes a virtual dual screen in-game.
Now, I want to figure out a solution for this, either find a solution for the game, (mainly burnout Paradise: the ultimate box). Or, if there is no problem game-wise, then find a way to change my external 16:10 monitor to a 16:9 aspect ratio, and then having the same resolution, because I'd be downgrading it from the higher resolution, higher aspect ration, to a lower resolution (1600x900) and lower aspect ratio.
I want there to be black bars, all possibilities can be checked, but I'd prefer having blackbars instead of distorting the screeen by stretching, or compressing the resolution to fit.
So, to summarize the above, I want to find a solution to be able to run dual monitor gaming, by cropping the resolution of my external monitor.
Thanks,
HPFREAK out~
Thanks,
HPFREAK out~
