My soundcard problem hope someone can help me..
  • Sound Cards
  • Movies
  • Components
Last response: in Components
October 27, 2011 3:34:22 PM
hi guys i have a problem with my soundcard..
when i play some sounds or watch some movies i get some sounds like cracking or like static sounds...i already search the google but no one have the right answer how to fix this..please help me ...,
More about : soundcard problem hope
October 27, 2011 3:36:36 PM
Soundcard or onboard audio?
There's a difference.
m
l
October 27, 2011 4:08:42 PM
its a soundcard..,,it so iritating to my ears when i play musics and movies as well...
m
l
October 27, 2011 4:18:13 PM
^^ Whats the soundcard? [Probably a Creative, which probably means Creative's drivers are at fault, which means I recommend either the Daniel_K or PAX drivers instead]
m
l
October 27, 2011 4:23:35 PM
^+1 what most people do who can no longer tolerate Craptastic drivers.
m
l
October 27, 2011 4:34:14 PM
ahmm it say here its a C-media PCI Audio device...i already installed the latest driver for it..but i think its the cards problem now..,,i think im gonna buy some new card..,but before that maybe someone can help me to fix this one...
m
l
October 27, 2011 4:39:48 PM
Move it to another pci slot.
Prefereably the furthest away from gpu=bottom slot
m
l
October 27, 2011 5:44:55 PM
More specific? C-Media based cards are used by about 8 differnet companies, so that doesn't rule much out.
m
l
October 27, 2011 6:05:49 PM
@ davcon i allready move it but nothings happen...
@ gamerk316 i dont know that what companie is this card dude..maybe ill try to remove some parts in my cpu..,
m
l
October 27, 2011 6:18:21 PM
Like gamerk316 said many companies use C-Media chips.
The card will likely have an identifying number stamped or stickered on it somewhere
Google it/them = find out maker
m
l
October 27, 2011 6:21:20 PM
then whats next when i allready found the companies who make this??
ohh god i can here like theres a popcorn inside my headset ahaha..
m
l
October 27, 2011 7:44:20 PM
^^ C-Media makes several soundcards, but sells them to other companies, which use the chipset as a base for their own models. As such, you need to find out exactly what drivers you need to install, as teh default C-media ones may not work properly.
For instance, my old Razer Barracuda, when drivers were not installed, was listed as a "C-Media audio device".
m
l
October 28, 2011 2:56:14 AM
when i put my soundcard here in my computer it automatically downloaded a driver for it so i know that i have the latest driver for it..,,but the problem is the sounds like crackling here in the headset when i play some sounds or playing games..,i dont know how to fix this..,,maybe i will buy some new soundcard...
m
l
