Please help, this is my first build and I'm quite disappointed I've spent so much money and it isn't even POSTing!
My system:
Motherboard: Asus P9X79 Deluxe
CPU: i7-3930K
Memory: Mushkin 993997 16GB (4x4GB, 9-11-10-28)
VGA: Zotac GTX 680
PSU: Seasonic Platinum 1000W
I also have connected to PCI-E slots:
Asus Xonar D2X sound card
Hauppauge Colussus video capture card
Blackgold 3600 TV tuner
And a Samsung SSD, 4 hard drives, and 2 optical drives.
All the above are connected up.
The problem is this:
On turning the system on, the CPU_LED on the motherboard lights up red and stays lit.
The Q-LED diagnostic display displays 00 (description in manual for this code is 'Not used').
There is no output from the graphics card.
The case does not have a speaker, so I cannot listen for beeps.
All fans (VGA, case and CPU cooler) are spinning.
I have updated to the latest BIOS via USB flash.
I have removed the RAM and placed one stick into different slots.
I have removed the CPU - none of the motherboard pins appear bent.
Does anyone have any ideas please on what I can do next? Will I need to replace some components, and if so, how will I know which is faulty?
Thanks!
My system:
CPU: i7-3930K
VGA: Zotac GTX 680
Thanks!
