Hello,
Today I attempted to connect my basement computer to my modem/router (SMC 2-in-1 device from ROGERS) via cat5e ethernet cable. First of all, good 30' of the cable is outside due to no other options, however it's nicely insulated by a plastic tube (one's used in cars so it shouldn't fall apart in rain/winter - it fit perfectly too). Rest 50' of the cable are inside. So total around 80' from modem to the desktop (max range is like 300 something feet so I'm assuming distance is not an issue for me). One thing to mention is that I was installing the ends by myself. It's my first time - not going to lie - it took me 4 tries replacing both ends to nearly perfect it. I started off with 568 A and ended up with B scheme, BUT IT STILL DOESNT WORK!!11....Modem has a flashing light at the port where I plug the cable in, however on my desktop it identifies the network for a min or so and then just dies with no internet. From pin 1 I inserted white/orange - orange - white/green - blue - white/blue - green - white/brown - brown ----- 568 B Scheme. I can see the copper ends on the back wall of the ice cube so short wires are not a problem. I tried the cable on my laptop and ended up with the same result. (Mind you all other stations at home work fine) What could I have possibly done wrong after 4 times re-doing the ends? Any help is appreciated
