Help Critique My Build
- Build
Systems
- Product
Last response: in Systems
lwhennen
July 30, 2011 7:10:34 PM
Below is my build mainly from newegg, i am planning on picking this all up from Frys within the next 2 to 3 weeks.I'd very much appreciate any critiques(glaring errors like bottlenecking and advice on different parts) and help in getting me the most bang for my buck.I also am willing to add 100 dollars to my build price in addition to the power supply which i am a bit concerned about how much power i really need...Thanks in advance for any and all assistance.
Memory-CORSAIR XMS3 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Motherboard-GIGABYTE GA-990XA-UD3 AM3+ AMD 990X SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Graphics Card-EVGA 01G-P3-1373-AR GeForce GTX 460 (Fermi) Superclocked EE 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP
Ready SLI Support Video Card
Processor-AMD Phenom II X4 980 Black Edition Deneb 3.7GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Desktop Processor HDZ980FBGMBOX
Storage-Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Dvd drive-LITE-ON 24X DVD Writer 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS424-98 LightScribe Support
More about : critique build
mjmjpfaff
July 30, 2011 7:51:43 PM
lwhennen
July 30, 2011 7:57:40 PM
- Help Critique My Gaming Build - Forum
- Looking for critique/help on a gaming build. - Forum
- Need critique/help on build - Forum
- New build critique- Some help please - Forum
- Help me critique my 1400$ PC build! - Forum
mjmjpfaff
July 30, 2011 8:10:48 PM
i5 2500k & evga gtx 560 ti- http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... 420$ after mail in rebates 450$ before
lite on dvd burner & seagate 1tb hdd- http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... 74$
gigabyte z68 ud4 & gskill 8gb 1600mhz- http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... 190$
Total=714$ before 30$ mail in rebate
ithink you already know this build is much more powerful
m
l
boiler1990
July 30, 2011 9:04:06 PM
mjmjpfaff
July 30, 2011 9:18:10 PM
what is your budget for your case and psu?
also get the parts i listed from newegg frys wont have the combo discounts.
if you need windows 7 here is it for 80$ after promo code EMCKCHB36- http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
lwhennen
July 30, 2011 11:35:36 PM
boiler1990
July 30, 2011 11:48:49 PM
The i5 crushes the best AMD CPUs on the market, and will most likely still trump the Bulldozer CPUs (if they ever come out). Plus, most i5s can hit 4GHz without touching the voltage, and I've seen records of over 5GHz OCs.
Comparison of the X4 980 (Black) and i5-2500K (Blue)
http://www.anandtech.com/bench/Product/288?vs=362
m
l
lwhennen
July 31, 2011 1:55:34 AM
boiler1990
July 31, 2011 2:13:03 AM
lwhennen
August 6, 2011 8:09:17 PM
What about this mobo instead of my orignal ? http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
madchemist83
August 6, 2011 8:31:40 PM
madchemist83
August 6, 2011 8:33:01 PM
m
l
mjmjpfaff
August 6, 2011 8:51:44 PM
madchemist83
August 6, 2011 9:06:35 PM
mjmjpfaff
August 6, 2011 9:35:20 PM
madchemist83
August 6, 2011 9:38:46 PM
mjmjpfaff
August 6, 2011 9:43:06 PM
madchemist83
August 6, 2011 9:52:14 PM
mjmjpfaff
August 6, 2011 9:53:17 PM
boiler1990
August 6, 2011 11:38:24 PM
madchemist83
August 8, 2011 3:03:24 AM
m
l
boiler1990
August 8, 2011 4:27:44 AM
The temps will be about the same, and generally depend entirely on airflow. Thought the 560Ti is a better card, a strict budget will force the OP to get a lesser card. The 6870 at least performs very comparably to the 560Ti.
I'm not a fan of the Frozr and most other custom cooler designs because the heat is exhausted inside the case, rather than outside.
Temp/power comparisons located at bottom.
http://www.anandtech.com/bench/Product/290?vs=330
m
l
madchemist83
August 8, 2011 8:10:04 PM
boiler1990 said:
The temps will be about the same, and generally depend entirely on airflow. Thought the 560Ti is a better card, a strict budget will force the OP to get a lesser card. The 6870 at least performs very comparably to the 560Ti.I'm not a fan of the Frozr and most other custom cooler designs because the heat is exhausted inside the case, rather than outside.
I would say it performs close to 560. But I guess at this price point you better off getting 6870. Also don't know anything about msi exaust problems but they get the job done with least noise. And for hot air getting trapped inside , if that what you mean when u say heat is exausted inside ( it's allways exausted inside first .. duh ), that's what side air ducts are for.
m
l
boiler1990
August 8, 2011 11:03:00 PM
We're just recommending the 6870 due to the budget constraint - otherwise I'd be wholeheartedly pushing either a 6950 or 560Ti.
Reference coolers generally exhaust out the expansion slot, so the hot air ends up outside the case rather than inside. I'm not fond of any aftermarket GPU cooler (not limited to MSI's Frozr), but that's just personal opinion.
m
l
madchemist83
August 10, 2011 4:28:44 AM
boiler1990
August 10, 2011 11:25:13 AM
Take a look at this and start trimming it down. You can definitely save on the case by dropping to an Antec 100, and there are numerous combos with CPUs, motherboards, and GPUs on Newegg that will save you anywhere from $10-30 usually.
http://pcpartpicker.com/p/HaK
m
l
lwhennen
August 17, 2011 9:11:03 PM
boiler1990
August 17, 2011 10:26:03 PM
The EVGA cards are great, and the one I put in that partpicker build has a lifetime warranty. Their warranty terms are pretty good too.
If you only want 8GB ever, the 4x2GB kit will be ok. It is technically a little slower than 2x4GB, but you won't notice it. The upside to 2x4GB is that you can drop in another kit if you ever need/want to. In general, the two types of kits are the same price or differ only by a few bucks.
m
l
lwhennen
August 20, 2011 4:10:27 AM
OP here update on my build completed as of a few hours ago
975 Be 3.7 ghz I believe down from the 980 due to no stock
4x2 gb ddr3 1600 ram from Kingston
700 w cooler master power supply
Cm II 690 advanced case
2tb 64 mb cache sata 3 7200 rpm hitachi drive
Pny 560 ti graphics card
Asus sabertooth 990 chipset mobo
A fairly generic Sony DVD writer / reader total cost 1100 well so much for budgets...
m
l
lwhennen
August 20, 2011 4:13:09 AM
mjmjpfaff
August 20, 2011 4:25:39 AM
well.... again the 970 is weak sauce compared to the i5 2500k. hitachi drives arent recommended. for 1100$ we can get you a gtx 570.
m
l
mjmjpfaff
August 20, 2011 4:44:57 AM
i5 2500k & Scythe Mugen 3- http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... 257$ with this cpu cooler you can easily get it up to 4.5ghz
Gigabyte Z68 UD3 & Corsair 8gb 1600mhz- http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... 193$
Corsair HX850 & Samsung F3 1tb- http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... 215$
Rosewill Blackhawk- http://www.newegg.com/Product/Product.aspx?Item=N82E168... 90$ great cooling. it actually cools better than the HAF X but it is a little bit louder
Asus DVD Burner- http://www.newegg.com/Product/Product.aspx?Item=N82E168... 20$
MSI GTX 570- http://www.amazon.com/MSI-N570GTX-Twin-Frozr-Power/dp/B... 325$
Total=1100$
Total=1100$
m
l
boiler1990
August 20, 2011 2:17:50 PM
Do you mean that you just configured it online in a shopping cart somewhere or actually built it. Even @ a $750 budget, mjmjpfaff was getting you an i5 and a 560Ti. The budget increase could have gotten a better GPU still paired with the i5...
Quote:
I am running the MSI TF3 6950 2GB and having a gpu made with quality parts that the manufactures used to factory overclock it makes me giddy. The fact that it disperses heat into the case doesn't change my opinion on it any since you still need good airflow even for a card that exhausts the heat outside the case. With my Raven's airflow design, the internal exhaust cards are essentially unacceptable. All of the air is moving up, so EE designs work significantly better.
m
l
mjmjpfaff
August 20, 2011 3:19:03 PM
boiler1990
August 20, 2011 4:03:15 PM
The EE design keeps the air from being dumped into the case, which would resist the natural/forced (4 fans directed upward) path of the hot air. It's more efficient for the GPU(s) to pull air upward out the top because the air is already moving that way, which makes it cool better (the Raven/Fortress series specifically). This doesn't apply to every case.
Plus, SLI/CF GPUs will be cooler since there isn't a heat dump on the PCBs. I've heard that there's somewhat of a problem with the Frozr coolers and this, but I haven't owned one so I don't know if it's a true design problem or just a case airflow issue.
m
l
madchemist83
August 20, 2011 7:22:06 PM
OK enough about air.
To Lwhennen:
First of all get mobo with one pci x save money which you can spend for better GPU. Like someone said even if you planning on getting second gpu later most of the people never do. Also progress goes so fast that you most likely to get a brand new gpu .. pcix 3.0 is coming soon. I put a built together with i-5 2500k and 6950 1Gb and thanks to microcenter it fit into 800 with shipping and taxes after MIR. So think about it ...
To Lwhennen:
m
l
boiler1990
August 21, 2011 4:55:30 AM
madchemist83 said:
OK enough about air.To Lwhennen:
We're trying to figure out if he bought that AMD config already...
m
l
madchemist83
August 21, 2011 5:42:17 AM
- SolvedHelp critique my gaming build, im looking to pull the trigger! Forum
- Build critique help Forum
- Noob needs help! check my build and critique. Forum
- SolvedFirst Build. Help/critique Forum
- Help/Critique on a new, first time build Forum
- Help with/Critique of My PC Build Please Forum
- Need Help - Critique My Build Forum
- SolvedNew build for BF3/Rage/Skyrim. Help, criticism, critique welcome Forum
- SolvedHelp! Last critique before I pull the trigger! (700$ build) Forum
- SolvedHelp with Build Plz. (was: Critique this potential build plz.) Forum
- Please help critique/improve my mid-range gaming build! Forum
- Critique and help me with my first PC build Forum
- First Build. Need help with choosing parts and overall critique. Forum
- $800 build critique and $600 build help!! Forum
- Critique/Help/Advice on my planned ~$700 Build Forum
- More resources
