Will these components work
I have a msi 760gm-p23 and it says on the box it supports AMD Athlon II but it only
has ddr3 ram slots will ddr3 work with a AMD Athlon II?
1 answer Last reply
More about will components work
  1. Hi
    CPU compatibility has nothing to do with ram compatibility if this is what you are asking.
    Hope this helps!
Memory DDR3 AMD Components
