New Build Help
Approximate Purchase Date: Mid August
Budget Range: $550
System Usage from Most to Least Important: Everyday use, gaming
Parts Not Required: CPU, RAM, Monitor, Mouse, OS
Preferred Website(s) for Parts: newegg, amazon
Country of Origin: U.S
Parts Preferences: Motherboard capable of using the CPU's integrated graphic
Overclocking: Maybe
SLI or Crossfire: No
Monitor Resolution: 1280 x 1024
Additional Comments: This will be my first PC build and so far I've only acquired 2 parts off sales.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
i5 2500k Sandy Bridge CPU $150 from Frys
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Gskill 8gb DDR3 1600 (12800) Ram, $55 from Newegg
so that leaves $345 for the motherboard, power supply, hard drive, cd drive, and case
For now I'm in no need of a GPU, the integrated graphic on the i5 2500k should be good enough according to the review I've seen on anandtech and notebookcheck. I play Blizzard games and I don't mind running them on low, but unless I misread the reviews then please let me know. I need help picking a motherboard out, not really sure which one to choose.
For a power supply I thought i'd go with this one allowing me to add in a decent GPU in the future
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
$64.99
For a hard drive I chose this, but would like some recommendations if there is a better one
$39.99
CD Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136222
$19.99
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
$59.99
That leaves about $160 for a motherboard. I would prefer not to go and get a $160 motherboard, some left over money would be nice.
Oh and this may be a stupid question, but would I need to buy anything to connect the computer to my router with an ethernet cable? or is it part of the motherboard? :??:
Anyway thanks for checking this post out :D
1 answer Last reply
More about build help
  1. Here's a better psu...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371047 $58.99 FREE SHIPPING 10% off with promo code Julsv10, ends 7/31
    Antec High Current Gamer Series HCG-520 520W ATX12V v2.3 / EPS12V v2.91 80 PLUS BRONZE Certified Active PFC Power Supply
    http://www.amazon.com/Gigabyte-Z68A-D3-B3-Intel-Motherboard-GA-Z68A-D3-B3/dp/B00518M78O/ref=sr_1_12?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1312093954&sr=1-12 $79.99 & this item ships for FREE with Super Saver Shipping
    Gigabyte Z68A-D3-B3 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard GA-Z68A-D3-B3
    http://www.amazon.com/Sony-SATA-Internal-Drive-AD-7260S-0B/dp/B003MRHOQG/ref=dp_cp_ob_pc_title_2 $19.99 Free Standard Shipping (3-5 days)
    Sony 24X SATA Internal DVD+/-RW Drive AD-7260S-0B - Bulk (Black)
    http://www.amazon.com/Samsung-Spinpoint-3-5-Inch-Internal-HD103SJ/dp/B002MQC0P8/ref=sr_1_1?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1312081809&sr=1-1 $59.99 & this item ships for FREE with Super Saver Shipping
    Samsung Desktop Class Spinpoint F3 1 TB SATA 3.0 Gb-s 32 MB Cache 3.5-Inch Internal Bare-OEM Drives, HD103SJ
    http://www.amazon.com/EVGA-GeForce-PCI-Express-Graphics-01G-P3-1366-TR/dp/B004DKWLB4 $156.98 & this item ships for FREE with Super Saver Shipping
    EVGA GeForce GTX460 SE 1 GB GDDR5 PCI-Express 2.0 Graphics Card 01G-P3-1366-TR
New Build Systems Product
