The Situation
I'm putting together a man-cave in the basement for my gaming/office needs. I'd like to incorporate a small intake fan (positive pressure) into a window
I've got a nice Platinum PSU in a new build, and am going to be using a fan controller (matches my case and gets good reviews) to help control the 3 main case fans in my new case.
The Rationale
I'm getting a controller with extra slots because I'd like to use it to control a fat or two outside the desktop, but powered by the PSU. This essentially to take advantage of the super-efficient power my PSU provides, and avoid having to get/wire another small inverter/psu to power these fans. The concern is whether I can use these fans when the computer is off. I know that some PSU's and some MB's provide power to some slots/outlets (typically a few USB ports at least) even when they're "Off."
The Goal
Wire up the power supply/mobo to the controller slots, and to the external fans (I'll have to get some Molex and/or 3-pin fan cable extensions) in such a way that allows for always-on controller and fans.
If that's not possible, wire it so as to at LEAST always be on when the box is on.
Anyone here have experience with this kind of mod?
The Rationale
Note: I don't want to use USB fans because they're only 5v and are typically too feeble for this application, and 5v doesn't travel well in long-ish wires.
The Goal
