Archived from groups: comp.sys.laptops (More info?)
Help anyone! I have a new Toshiba A75 laptop--only a few months old.
Suddenly, the AC power plug does not seem to be working. The battery
is down to 13% even though it's plugged in to the wall. I checked all
the connections, unplugged and plugged them again; I tried another wall
outlet, just in case. But the battery is draining and no power is
getting to it. Anyone heard of this? When I pulled the power cord out
of the back of the machine, it made an odd squeaky noise. Other than
that, I have no symptoms to report.
Please let me know if you have any ideas. I tried searching Ask Iris
on the Toshiba site, and of course, found nothing.
dianadiehl@cox.net wrote:
: Help anyone! I have a new Toshiba A75 laptop--only a few months old.
: Suddenly, the AC power plug does not seem to be working. The battery
: is down to 13% even though it's plugged in to the wall. I checked all
: the connections, unplugged and plugged them again; I tried another wall
: outlet, just in case. But the battery is draining and no power is
: getting to it. Anyone heard of this? When I pulled the power cord out
: of the back of the machine, it made an odd squeaky noise. Other than
: that, I have no symptoms to report.
The "squeaky noise" could be an indication of a loose or even broken
power connector on your laptop, which would make it impossible for
your laptop to get power. Unless you are handy with a soldering iron,
you're going to have to get it serviced in that case. Is it still
under warranty?
What if you wiggle the plug going into your laptop just a tad? Do you
notice the power coming back on, even briefly? (Seen most obviously
by the power LEDS coming back on.)
Or, the "squeaky noise" might have always been there and is a normal
sound and your AC adaptor simply died. Mine died on my Toshiba
Satellite slowly last fall - at first, I could twist and turn the
black box part of the adaptor a few times until power kicked in (not a
connector issue, since I would do this without touching the laptop
end). It just got worse and worse until it completely stopped
working. I got a replacement from Ebay which has worked perfectly
ever since.
Andrew
----> Portland, Oregon, USA <----
----> http://www.bizave.com <---- Photo Albums and Portland Info
----> To Email me remove "MYSHOES" from email address
If it's only a few months old, it's under warranty.
Problem solved.
> Regards,
> Diana
Additional symptoms/facts:
* Of the 3 lights in the front, the first one that has a plug icon
stays on and green.
* So does the middle light.
* The 3rd light is not on now, but yesterday, it was glowing orange.
* Now, with the 2 green lights on, if I scroll over the task bar item
for the battery, it states that the machine is on battery power, and
the battery charge gradually decreases
* I left the machine plugged in all night last night and power was up
to 97%.
* I left the machine plugged in all day today and it was only at 67%
when I came home.
* My nice bright screen is fairly dim. Occasionally, it brightens up
for a few seconds and reminds me why I bought this model.
I have to check the warranty and hope that it's for a whole year. If
not, I'm going back to Dell's. the trick now is to pull my hard drive
and get a replacement while this is in the shop. I have to be able to
compute for a number of reasons, including work.
I wish there were a quick answer--and no, I am not good with a
soldering iron. Thanks for your reply (everyone).
Diana
> under warranty?
> What if you wiggle the plug going int* o your laptop just a tad? Do you
> ever since.
> Andrew
Hi, here's an update on my Toshiba Satellite A75 with the failing power
cord. I took it in for repair today. The service rep says this is a
known problem with this and one other model (M35? Sorry, can't
recall). About 60% of this model fail because of a poor connection
between the power cord receptacle and the motherboard. They will have
to replace the motherboard one that has a properly attached/epoxied
power cord receptacle.
The squeaking that I had heard, the inability to get power from the
cord when the battery was removed, and the apparent looseness of the of
cord (it wiggled easily when I plugged it in) were diagnostic. This
assessment was at first glance, so I do not consider it to be the final
word, but I consider this to be gross circumstantial evidence
supporting the most likely cause. Thanks all for your time and
comments. Wish me luck for going cold turkey for a week. (All my
other computers are disabled or disposed of)
Regards,
Diana
> Regards,
> Diana
