How much power for i5-2500k @4.2 and 560tiSli
  • Power Supplies
  • Overclocking
  • Intel i5
  • Power
  • Components
Last response: in Components
October 29, 2011 2:28:06 AM
I am planning on getting the i5-2500k and overclocking it a bit and will get a 560ti and add one later
When does adding cards become not worth it e.g 6 months, a year, 2 years?
If i was not to sli the 560ti how much would i need with overclocking?
Any suggestion for under $100 bucks before rebate, modular would be great but if its not possible its ok
More about : power 2500k 560tisli
October 29, 2011 2:38:42 AM
For SLI rig I would recommend corsair TX 750.Corsair PSUs have a superb build quality and can also provide extra Amps when needed.
It will always remain worthwhile to add another card.The only problem is you might not get the card after another six months.So you should get another card before they run out of stocks.
You can't achieve performance level of two 560ti in sli with a single overclocked 560ti.The two in sli would perform better than gtx580 for much less cost.
m
l
October 29, 2011 2:40:29 AM
would it be alright if i got another in like a year or 2, or just update to the newer stuff?
m
l
October 29, 2011 2:41:07 AM
either way i may as well get a future proof PSU
m
l
October 29, 2011 2:43:40 AM
Like I said you won't get another card after a year or 2.Although if you can get it would be worthwhile because you'll have to pay a lot less to get the next card.
m
l
October 29, 2011 2:50:11 AM
Investing on a good PSU is always a good idea.850W from a good manufacturer should be enough.Although the GPUs will become increasingly more efficient in the years to come you might not need so much power even for sli.But still the remaining power could be used for liquid cooling and other stuffs.
m
l
a c 275 ) Power supply
a c 183 K Overclocking
October 29, 2011 3:10:17 AM
You would be fine with a 750W unit imo.
Core i7 965 / X58 system @ 3.75 GHz
http://www.guru3d.com/article/geforce-gtx-560-ti-sli-re...
Full system power draw @ 450W.
What i would buy.
Antec Truepower New 750W Modular
http://us.ncix.com/products/?sku=36264&vpn=TP%2D750&man...
m
l
