PLEASE HELP!(Motherboard)
Hello,
This is for my old home computer.
I have 2.66GHz intel pentium D (with 533Mhz FSB), 1.5Gb 533MHz RAM, Intel Desktop Board D102GGC2.
My motherboard D102GGC2 is not working now and I need to buy new one.
Suggest me a LGA775 Socket compatible good motherboard.
I had gone through other posts and Found "ASRock G31M-S R2.0" a good option, but i would like to get 1 or 2 more options, since i am not getting this at my local dealer shop.
Thanks,
Argha
More about : motherboard
First of all, THANKS a lot for your quick reply.
I recently had went to my local vendor, to change my SMPS. He only told that i need to change my Motherboard some time later.
The PROBLEM in my PC is, that it is normally working well for 15-30 min, then there is a sudden restart. then it works for 15 -20 min , and after that it restarts again.
I would really like a conformation from your side, if u have idea, that it is a problem of MOTHER BOARD or not.
Moreover my Processor is '05A Platform compatible'. So could you please suggest me some good Motherboards which are "05A Platform compatible."
o1die said:
http://www.ebay.co.uk/itm/COMPAQ-HP-D530-Pentium-4-2-66...
I would checkout some used combos if they're cheaper; you may have a problem with your cpu and you won't know until you try another board. With such an old cpu, a new motherboard isn't worth it. Lots of good g31 boards; just check the "cpu support" section with your cpu model number on the lid before you order.
Ask the community
