Solved
Building a gaming machine any help?
Last response: in Systems
Building a gaming machine for BF3 so far we are at $500 for the setup anyone have an idea on the graphics card I can get?
Rosewill steel ATX Mid Tower Computer Case
MSI 970A-G45 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard (For bulldozer of course)
AMD Phenom II X4 840 3.2GHz Socket AM3 95W Quad-Core Desktop Processor HDX840WFGMBOX (Temp processor till bulldozer)
G.SKILL NS 4GB DDR3 RAM
Seagate Barracuda 1TB 7200 RPM SATA 6.0Gb/s
ASUS CD burner 24x
Antec 650w psu
I am only missing a video card for this setup any help, ideas?
Homebuilt system Expert
Hi, drop down to a 500W PSU from either Antec or Corsair. A DVD burner from Lite-On or Sony Optiarc is only $20 free shipping. May want to switch to Samsung Spinpoint F3 1TB 7200RPM for better performance. I like using ATI but that's just me. You can find a 460 for around $120 after MIR or go for a 6850 for $135 after MIR maybe. If you plan to oversli get at least 700W.
How much can you spend on a video card? If your budget is:
~$500, I would go for the GTX 580.
~$300, I would go for the GTX 570.
~$200, I would go for the Radeon HD 6950
~$100 You should get some more money together if you want to run BF3.
Related ressources
You shouldn't spend any more than $20 on the optical drive. Sony Optiarc and Lite-On has $20 free shipping on newegg. There's also the Asus oem one but it's $1 shipping but Amazon has the same model for $20 free shipping. For $200 I would buy the 560ti. If you look, there should be a OC'd one for around $200 after MIR. 560 ti < 6950 < 560 ti OC'd.
I respectfully disagree. On higher resolutions the 6950 out-performs the 560 ti. And I would rather not OC if possible, but that's just me.
http://www.guru3d.com/article/radeon-hd-6950-1gb-vs-gef...
You do know I placed the 6950 between the 560 ti and an OC'd 560 ti? That does mean that at stock performance without factory overclock.. the 6950 will outperform the 560 ti. I don't know why are you disagreeing lol.
I added the Antec PSU for 650w, but now I need a video card I can spend up to $300 so any suggestions? And the ram I am buying in 2 qtys so I get 8gb instead of 4gb. I am thinking of a GTX 570 or would a 6970 work?
the 6850 should run quite well for only 150. also, that processor is crap. for an extra 10 bucks on tiger direct, you can get a amd 955, quad core 3.2 ghz cpu with 2000 mhz bus speed. that one's bus speed is only 667.
Best solution
That depends on what game you're playing and at what resolution. The 570 and 6970 are even in some areas, and clear winners in others. Here's a benchmark. You should be within the fps you see in the list. http://www.anandtech.com/bench/Product/306?vs=292 Regarding his choice of a 840. It is better to purchase a Phenom II x4 955 which can be had for around $120 [should check] but seeing how it's only a temporary CPU to fill in. It should fill his needs, dont ya think? :p
Ask the community
