I'm hoping someone could clarify a problem I'm having. Several months ago I built the following system:
CPU: Intel Core i5 2500K 3.30GHz
Motherboard: ASUS P8P67 PRO
Memory: Corsair XMS4 4GB DDR3
Graphics Card: NVIDIA GTX 285
Power Supply: Corsair TX 750W
Case: Hiper Osiris (an old one I've had for nearly three years)
Everything was fine until recently when I started to experience a cold boot problem. If the computer was switched off for several hours, when I would go to start it up the lights on the case would come on and the fan would start but after a few seconds the computer would shut down without reaching the BIOS. It would then start up by itself again immediately and boot successfully.
I checked all the connections and tried removing the various components (hard disk, graphics card etc) individually to try and identify what was causing the problem, but had no luck. Then I tried disconnected all of the case's front panel connector wires from the motherboard and powered the computer on by shorting the PWRSW connectors on the motherboard. I found that if I powered the computer on using this method the cold boot problem would not occur.
My question is does it sound likely that this is the cause of the cold boot problem. If yes then I'm happy to buy another case, as the one I have is pretty old. Otherwise I can still RMA the components.
Thank you in advance.
