Help Selecting a Case?
  • Power Supplies
  • Cases
  • Computers
  • Components
  • Product
Last response: in Components
October 31, 2011 3:49:35 AM
Im looking for a mid-tower case to get for a computer I'm building, but I'm having trouble finding the right one. The biggest issue is finding one that will fit a Radeon HD 6950 GPU, which is about 11 to 11.5 inches long. The mobo is a standard ATX and I only have one HDD. I'm looking for something with decent ventilation, and preferably some sound dampening. As far as budget, I'm hoping to spend $50 or less, but I'm a little flexible in terms of price.
More about : selecting case
October 31, 2011 4:10:39 AM
Ok so I've read up on some stuff and realized I'll probably also have to look at full towers, so recommendations on those are appreciated too. But again, I'd like to spend under $50 or $60 (if at all possible!).
m
l
October 31, 2011 4:14:47 AM
Why not go for a full tower?
m
l
October 31, 2011 4:18:53 AM
The main issue is price, but I might have to go with one anyway.
m
l
October 31, 2011 4:22:00 AM
^ True.
How much are you willing to spend on a case?
m
l
October 31, 2011 4:25:10 AM
trihedral said:
^ True.
Ideally, $50 - $60 USD, but I'm realizing I'll probably have to shell out more, maybe closer to $100.
m
l
October 31, 2011 4:39:20 AM
$100 would be plenty.
There are some really cruddy cases under $70.
Are you planing on overclocking?
m
l
October 31, 2011 5:12:47 AM
Cooler Master's HAF 912 should be perfect for your needs. It goes for about 60 USD at newegg.com. If you take out one of the removable drive cages your card should fit with room to spare.
Hopefully you'll see this before you make your final decision!
Best of luck,
Will
m
l
October 31, 2011 5:29:49 AM
I'll be running an i5-2500k at 3.3GHz with a CPU cooler and a Sapphire Toxic 6950 GPU at 880MHz with a built in fan and vapor cooling system. The GPU is factory OC'd. And honestly, I'm fine with a cruddy case as long as it functions according to my specifications haha.
Best of luck,
Will
Thanks I'll take a look at it!
m
l
October 31, 2011 6:05:29 AM
So I've decided to go with ihateenglishweather's choice of the CoolerMaster HAF 912. Although it's a bit pricey, I think it offers the most in terms of internal spaciousness, air flow, and sound reduction. Thanks!
m
l
October 31, 2011 6:12:01 AM
^ I agree.
The CoolerMaster HAF's line is very well built. It has good room to fit almost anything, even a little child. I've had good experience with those cases. +1
m
l
