Solved
Power supply wont turn on
Hello everyone a newb question here
when i plug in the power supply and turn on the switch (the power supply by itself not attached to anything)
the fan doesnt spin or anything? Does it have to be plugged into the components to turn on?
Only my power supply has come so far so i cant test it with the other stuff and im wondering if im just dumb or if the psu is faulty thanks
4 answers Last reply Best Answer
More about power supply wont turn
  1. Best answer
    It has to be plugged in or at least with the paperclip method! http://www.overclock.net/faqs/96712-how-jump-start-power-supply-psu.html
  2. If that ^ doesn't work ,it's dead.
  3. thanks ill try the paperclip thing
  4. Best answer selected by mike1213.
Power Supplies Switch Components
