Hello I'm doing my first PC build right now and my Corsair TX750 V2 PSU's screw holes aren't aligning up with my case's PSU screw holes. (my case is a Corsair 400R)
Two of the screw holes on one side align perfectly but the two on the other side don't, one of them shows off half of the hole and the other is not even close.
I'm sure I have the PSU positioned correctly, with the fan pointing down to the case's bottom grill, and I've tried to wiggle the PSU any way I can to try to get the last two screw holes to align but it's not working. What I find funny is that both the case and the PSU is from Corsair, WHY wouldn't there own two products work together??
