Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > New Build Help
New Build Help
Forum Systems : Homebuilt New Build Help
Ok I was running on an old ibuypower laptop and that died not that long ago so i ordered a new one which was pretty much a copy of the $1000 system builder build. I start it up and it doesnt post or display anything
ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor
XCLIO Nighthawk Black Finish 0.6mm SECC ATX Mid Tower Computer Case
HIS CrossFire Bridge Interconnect Cable Model HCFBC4065
Western Digital Caviar Black WD7502AAEX 750GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
MSI P67A-G43 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
2 x GIGABYTE Ultra Durable VGA Series GV-R685OC-1GD Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
LG CD/DVD Burner Black SATA Model GH22NS70 OEM - OEM
I've tested it every which way. It powers up everything turns but it doesnt post or display anything
CPU gets hot
All my fans start
All my lights turn on
Harddrive starts
CD Rom works
Graphics cards start
tested my ram
And when i couldn't figure it out i had my brother look at it he majored in computer science and he couldn't figure it out
Any help would be most appreciated . :D
Reply to imbigbuck
I've triple checked them. I think the chances of receiving TWO dead gpu's at once are slim at best
Reply to imbigbuck
well run each one separately, see what u get
Reply to starravier
Just figured it out. I used the top PCi for all my tests and then just for fun i put one in the bottom and it worked fine! Although im not sure if its a primary/secondary or a the top ones broken thing.
Reply to imbigbuck
There are 2021 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What level would you consider this?
By austinwillie_95, 2 hours ago:
It won't handle high end games that's for sure. And for $800 you would be better off just...
Best offers
Top experts
