Help with first build PLZ!!
Ok so I managed to build my pc for the first time and when I connected it to the monitor I managed to get into the bios and it looked like everything was working. I then tried to manage the cables and put the case back together and I'm having the following problems:
The heatsink fans aren't turning on when they were before
I am getting no loading screen or any signal through to my monitor
And when I turn the computer on with the power button I can't turn it back off
Are their any likely parts I have damaged or should check? All advice is appreciated thanks!
4 answers Last reply
More about help build
  1. Go through this guide step by step http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems pay attention to the motherboard standoffs.
  2. Ok thanks
  3. Found the problem the separated 4 pins on my 20 pin motherboard power supply had slipped slightly out when i tried to manage the cables!
  4. Great all running good then?
Build Systems
