Hey guys,
So I've built my first gaming cpu, put together as you guys recommended. Its running great!
However, in the Rosewill challenger case and evga gtx570 superclocked, the card seems to produce lots of heat when gaming. Also, my monitor seems to get heated easily. So my questions are:
1) What's the best way to monitor the temperatures?
2) What do you think about a cooling unit, like: http://www.amazon.com/Vantec-SP-FC70-BL-Spectrum-System-Adjustable/dp/B000233ZMU/ref=sr_1_2?s=electronics&ie=UTF8&qid=1312476570&sr=1-2
3) Should I return my asus monitor and get a LED-backlight one of the same (1080p, similar price) size? Is it worth the trouble?3
In addition, I see in my C drive that there is a folder for program files and one that says program files (x86). My games, SCII and Crysis, seem to be installing in the x86 folder. What is this?
