Closed
P8Z77-V boot problem after soundcard installation
Today I received my Asus Xonar DG Soundcard from Amazon. I read in the manual for the card that I should disable my onboard audio, so I booted into my Asus P8Z77-V's UEFI and disabled it. I installed the audiocard, plugged everything back in, and lo and behold, no response from the computer. I removed the soundcard, and again, no boot. I even removed my videocard, and all SATA drives and fans, so only the power connectors and case switches remained plugged in. Still no response. I'm inclined to believe that my case (a slightly modded Cooler Master HAF 912) has a broken switch, but I'm not sure, since I got the case just last year, brand new. Any help?
Motherboard Master
To test your switch you can use flat head screwdriver to jump the start switch pins on the motherboard, if that does not work either PSU or motherboard is the most likely problem.
Related ressources
Motherboard Master
themissingpiece said:
So do I just tap the power SW pins with a flathead screwdriver?
Yes just a quick touch on both will imitate you pressing the switch.
I got no response from the system. What now? I'm getting pretty scared now, and I'm afraid that I might have to RMA my motherboard to Asus, and I've heard horror stories about how bad Asus's RMA service is.
Motherboard Expert
have you checked your mobo and case stand offs? its probably shorting with the case.
might want to check the troubleshooting link in my signature :??:
Motherboard Expert
isn't there a way to revert to your default bios settings? BIOS flashback via usb? t'll take me some time to get back with the details in your manual...
Motherboard Expert
oh wait have you taken the battery out of mobo?
Edit: the post by rolli reminded me of a key factor!
what are you full system specs(include your sound card) !?!?
Intel Corei5 2500k
Asus P8Z77-V
16GB Patriot Sector 5 DDR3 1600
120GB OCZ Vertex 3 (boot)
2TB Hitachi Deskstar 5900rpm (data)
EVGA GTX 460 SE SuperClocked
Thermaltake Toughpower 775W Power Supply
Asus Xonar DG (soudncard)
Motherboard Expert
then apart from the board being dead I could pin this on a bad bios - but your board seems to ship with version 0801 by default and it supports i5-2500K natively.
I will. Is it ok if I head to my nearest Fry's (tech store) and buy a replacement motherboard, but return it later while Asus RMAs it? Because right now I really need to use my computer and access my data, but no way access it. And I'll try to be as gentle with the motherboard as possible. :p
Quick update on my situation:
RMA'd mobo comes back. Fans, LEDs, turn on fine. However, red light by the the RAM slots, indicating bad DIMMs. Unusual, but not uncommon. I stick a PCI diagnostic device to get a better look. I get the diagnostic code 55. I doesn't tell me what it means in the device manual, which worries me. I remove the PCI card and try again. Uh-Oh. It's just like last time. No response, no boot. I've already sent an email to Asus asking me for a report on how to resolve the problem myself so I don't have to spend $21 + on shipping it to them.
Good news (if any) is, I've cut the problem down to something with my PCI slots. Any ideas?
Ask the community
