GFX Card Help
My Specs: View sOgXRe.png on ScreenSnapr
1) Can someone point me to a GFX card that I could run the Witcher 2 on high settings on ? Trying to get one that is $150 or less if possible.
2) Below would be the new power supply I would buy will that work with my computer/gfx card?
Power Supply:
http://www.amazon.com/gp/product/B002RWJGHM/ref=ox_sc_act_title_1?ie=UTF8&m=ATVPDKIKX0DE
Thank you
3 answers Last reply
More about card help
  1. to be frank even high end gpu have trouble to run the game smoothly. currently my GTX460 have to crawl to run the game on high setting with 1600x900 resolution (though you can turn off some setting such as DOF and SSAO to gain more frame rates). what is your gaming resolution?
    you can get this for $150 if you include the MIR:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127576&cm_re=HD6850-_-14-127-576-_-Product
    according the spec i found on dell site you PC only come with 300w PSU. if you're going to use card that in the range of $150 a new PSU is a must. the PSU you linked above should be fine to handle mid range gpu but i heard some people say thermal take PSU are not very good. most people will choose reputable brand such as antec or corsair.
    Thanks for the responds. My resolution is 1600 x 900. If I bought a 600w power supply & that gfx card do you think my computer could handle medium settings ? Also is it possiable to get this one or is the other much better ? http://www.amazon.com/EVGA-GeForce-PCI-Express-Graphics-01G-P3-1366-TR/dp/tags-on-product/B004DKWLB4
    Edit: I think thats your gfx card ?
    never did try the game on medium setting but i think the performance should be fine. btw mine was GTX460 from Asus as i state in my sig
Graphics Cards Power Supplies Computer Graphics Product
