[Help] Ram frequency issue
Hey there ! I just finished building my new rig (Wouhou !), but for some reason, my ram only runs 1067mhz instead of 1600mhz. My mobo http://www.newegg.ca/Product/Product.aspx?Item=N82E16813138357 only gives me the option to run it at 1067mhz even if I change the timings to the right ones. This is my ram http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231193
Any help would be very appriciated !! :D
4 answers Last reply
More about help frequency issue
  1. Look for the settings in your BIOS pointing to the FSB of the CPU being linked to the speed of your ram somewhere. Most BIOS have a setting that locks the speeds together, either in a 1:1 ratio, or a 3:2 ratio, etc.
  2. could it be ia core current max (1/8) ?? thanks a lot for your help.
  3. Whats your CPU?
  4. My CPU is a Pentium G620 2.6ghz, it's locked
Chipsets RAM Motherboards
