Will this system work?
Last response: in Systems
Okay here is a system i was thinking about buying. Will these parts be compatible with each other?
BIOSTAR TP67XE (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard:
EVGA 01G-P3-1371-TR GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card:
CORSAIR Enthusiast Series CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply:
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K:
G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL:
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Approximate Purchase Date: This week
Budget Range: 800-1000
System Usage from Most to Least Important: Gaming most
Parts Not Required: Keyboard,Mouse,Speakers.
Preferred Website(s) for Parts: Newegg
Country of Origin: United States
Parts Preferences: Doesn't matter
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: Don't know yet
More about : system work
Homebuilt system Expert
CPU: Intel Core i5-2500k $220
MOBO: Biostar TZ68A+ $100
RAM: Kingston HyperX KHX1600C9D3K2/8GX $55 before $15 MIR
GPU: XFX HD-687A-ZNFC Radeon HD 6870 $180 before $30 MIR
HDD: Samsung Spinpoint F3 1TB $60
CASE: Rosewill Challenger $50
PSU: CX600 V2 600W $70 [$20 MIR and $10 off promo available]
Optical: Sony Optiarc $20
OS: Microsoft Windows 7 Home Premium SP1 64-bit
Monitor: Acer G235HAbd 23 $150
$1005 before MIR/ $930 afterward
I prefer this monitor but it's more expensive so I won't recommend this but it's something you can opt for instead of the Acer.
Asus VH236H Black 23"
The Biostar seems to have got good reviews and actual manufacturer's response to those who gave it like 1 egg so I'll stick with it. I don't suggest dropping to a HD 6850 because I think you'll only save around $10 to $20 at most and the 6870 is a really good card.
If you're really not going to overclock, you can safely drop down to a core i5 2400 along with a H61/H67 and that will save you a lot fo money. I do recommend overclocking the i5-2500k, it will be a good experience for you and it's easy too! The CPU is well-known for its easy overclockability and awesomeness :)
Well turns out my mom already ordered these parts :??: . So could i possibly make my current specs work?
Homebuilt system Master
^ All compatible. Can you return them?
You kind of spent more than you needed to. IE. Power supply, I think the GPU was a bit pricey for how much it performs. The 550 Ti would've saved you a bit of money for similar performance. You're not overclocking or SLIing so you don't need P67 or the 2500K. You could've saved around $90 by dropping down to an H61 and a 2400.
Ask the community
