Help, which motherboard???
I have a "Acer aspire am1641-u1521a" and it's not booting up. The fans and led turn on but nothing comes on the screen. The motherboard has two bulging capacitors. The chipset is "NVIDIA GeForce 7050 / nForce 620i" but i can't seem to figure out what's the motherboard model so I can buy a new one and try it out.
4 answers Last reply
More about help motherboard
  1. Run Speccy @ http://www.filehippo.com/download_speccy/ and check the findings : )
  2. I can't 'cause the computer won't boot up.
  3. I doubt you will be able to find a replacement mobo for much cheaper than it would take to get a more recent CPU and motherboard and put it in the current case.
Motherboards LED Monitor Product
