Closed Solved
Will this graphics card work?
Operating System
MS Windows XP Home 32-bit SP3
CPU
AMD Sempron LE-1300
Sparta 65nm Technology
RAM
2.0GB Dual-Channel DDR2 @ 330MHz (5-5-5-15)
Motherboard
Dell Inc. 0RY206 (Socket AM2 )
Graphics
DELL E198WFP (1360x768@60Hz)
64MB GeForce 6150SE nForce 430 (Dell)
Hard Drives
156GB Western Digital WDC WD1600AAJS-75WAA0 (SATA)
I have a DELL INSPIRON 531s and i was wondering if an Nvidia Geforce 9500GT would be compatible with it
other info: Power Supply: 250watts and 12V/ 17Amps
7 answers Last reply Best Answer
More about will graphics card work
  1. Your GPU of choice requires a 350w PSU. It may work with your Dell PSU, but it will put a heavy load on the system and will likely shorten the life of your PSU. You can always upgrade your PSU as well.
    Good luck!
  2. ok so my question now is will the card fit since it is a Dell Inspiron 531 slimline model
  3. Not unless the card you are looking at is a low profile version. Here is such an example of an ATI card in that format:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814102874&cm_re=hd5570-_-14-102-874-_-Product
    I use this same GPU in a Shuttle XPC system with a 250w PSU with no issues. Worth checking out. Very good performance for the cost.
  4. so that card needs 350w yet you use it with a 250w power supply? i dont see how your computer has blown up yet.
  5. Best answer
    I have a low wattage CPU, a slow spinning HDD (5400 RPM), and no OCing of any sort. The only time I have had any sort of issue was when too many USB devices were attached (drawing too much power from the system). I simply manage the power of the rig.
  6. Best answer selected by 12345690.
  7. This topic has been closed by Mousemonkey
Graphics Cards Graphics Product
