I have just built a new system and when I turn the power on at the wall the fans turn on and off repeatedly. This is before I press the power button to boot the OS. The fans are powered through 4 pin molex's because there wasn't enough fan headers on the mobo.
I thought I may have got the front panel power switch connector in the wrong way or on the wrong header on the motherboard and after consullting the motherboard manual and checking and then double checking the problem still persists.
The PC actually boots fine and operates as normal but im concerned that this power fluctuation might damage some of the components.
Ive had a good old googling session trying to find an answer but have been unsucessfull so any help wold be great
PC Specs
Core i3 540 3.10GHz @ 4.20GHz Overclocked (This came pre-overclocked in a PC bundle)
Gigabyte GA-H55M-UD2H
4GB DDR3 Dual Channel Muskin Silverline
Nvidia GTX 560
WD 1TB SATA
700W OCZ ModXStream PSU
Antec 100 Case
Thanks in advance
Phil
PC Specs
Nvidia GTX 560
WD 1TB SATA
Antec 100 Case
Thanks in advance
Phil
