Help Me Build a 1000-1500 build (buying at FRY's in 10 Days)
Approximate Purchase Date: (10 days)
Budget Range: (1000-1500) Before Rebates
System Usage from Most to Least Important: (Gaming, Storage for Music, Media Editing)
Parts Not Required: Need Everything but speakers
Preferred Website(s) for Parts: FRYS.com
Country of Origin: (United States)
Parts Preferences: Was looking a AMD Phenom II 1090t Black Series
Overclocking: Maybe but probably not until 6 months with the machine
SLI or Crossfire: Don't really know what these are but maybe?
Monitor Resolution:Whatever works
Additional Comments: I would like it sleek but with leds. Starcraft 2 Ultra graphics would be nice and possibly ssd if it works in the budget
1 answer Last reply
More about help build 1000 1500 build buying days
  1. I didn't see SSD's on fry's web site. I recommend either a Samsung 470 series 64GB or 128GB or a newer Crucial M4 64GB or 128GB as your budget can hold.
    I didn't pick out a Keyboard or mouse, you can shop for these there. a basic KB and Mouse $30 or you can get gaming quality ones. its your budget. I picked a good gaming monitor (fully adjustable), but look around at fry's and see what on sale. the spec you want to look at is the response time it should be no more that 5ms (grey to grey) for gaming. for the Optical (DVD) drive I put in a place holder, just see whats on sale any 19-$25 (asus, LG, Samsung,HP) drive will be good. for the HDD again I picked a solid one, but look to see whats on sale. get at least a 500gb one that has 32mb of Cache and runs at 7200RM. if its a Western Digital HD get the 'Black" edition these are the faster drives. I picked a good gaming case that has 4 fans and a built in fan controller (looks cool too). The GPU will game well for some time to come without breaking the bank. I went with an Intel Sandybridge CPU as they are the best gaming CPU out right now and it was in your budget. Ram was decently priced so I loaded you up with 8GB even though 4GB would do.
    BTW: you could save loads of money ordering via newegg and amazon, but fry's is instant gratification :D
    FRY'S Shopping list
    6686664
    DDR3 8GB 1600MHz DUAL CORSAIR
    http://www.frys.com/product/6686664
    $79.99
    6335791
    Samsung 1TB Serial ATA 3.0Gbp, buffer memory 32MB- HE103UJ
    http://www.frys.com/product/6335791
    $64.99
    6519023
    ASUS GTX560Ti OC 1GB 1GB DDR5 MEMORY
    http://www.frys.com/product/6519023
    $249.99
    6251250
    Corsair Gaming Series GS600 High Performance PSU ATX Power Supply CMPSU-600G
    http://www.frys.com/product/6251250
    $78.99 $78.99
    6672554
    Gigabyte GA-Z68X-UD3H-B3 Intel Z68 1155 Motherboard
    http://www.frys.com/product/6672554
    $169.99
    6028088
    Windows 7 Home Premium 64bit(Full) - System Builder (OEM) version - DVD
    http://www.frys.com/product/6028088
    $79.99
    6690504
    Zalman Z9 Plus Mid-Tower Gaming ATX Case
    http://www.frys.com/product/6690504
    $67.99
    6568133 SAMSUNG 24X OEM DVD-RW
    http://www.frys.com/product/6568133
    $19.99
    6487382
    Intel Core i5 2500K Boxed Processor 2nd Generation Sandy Bridge CPU
    http://www.frys.com/product/6487382
    $214.99
    6279270
    ALIENWARE AW2210 21.5" LCD PC MONITOR
    http://www.frys.com/product/6279270
    $189.99
    $1,216.90 you can get a 128GB SSD as mentioned above for $230 or 64GB for $120. the bigger the better
Build Systems Product
