theprodigy001
5
hello everyone,
i am going to start building my first system.but first i have a few questions.
what is a good mother board.
and how do i know what parts are compatible with a particular mother board.
the processors i was looking at where the amd 1100T and the intel i7 2600k
what would be a good mobo for each of the processors.
theprodigy001
5
i like surfing the net,watching tv,movies and videos online,and i would like to play games.mostly first person shooters and racing games .also i usually watch tv online while on face book or doing something else so multitasking.
thanks for the help
Engima
711
Here are some questions to answer before recommending any motherboard.
1) Do you want an AMD or Intel processor (the 1100T or the i7)?
2) Do you plan to SLI/Crossfire in the future?
3) Do you have a preference for USB 3.0?
Realistically speaking, any motherboard on the market right now is good but there will be those that have problems due to the manufacturing process.
dalmvern
673
Like has been said, the the definition of a good mobo is very open. In order to make sure the components are compatible, look for the socket. For example, the Intel SandyBridge series is a LGA 1155 socket, so you would look for parts compatible with the 1155 socket.
Keep in mind that since your entire build revolves around your motherboard you have to make alot of decisions before you should buy one. Also keep in mind that most expensive is not always better FOR YOU.
A good example of this is the i7 2600K you are looking at. I think you would probably get better use of either the i5 2500 or 2500K, depending on whether you plan to Overclock or not.
theprodigy001
5
yes i would like to over clock.would the i-5 2500k be faster then the amd 1100t?
also when over clocking should i purchase a after market cooler for the CPU?could i over clock with any mother board or are there specific ones i need to use?
Engima
711
Most modern motherboards will allow you to overclock but you will definitely need to use an aftermarket cooler. I think you should read more on overclocking before you do anything since you don't sound too informed about it.
theprodigy001
5
i have been reading up on the I-5 2500k and it seems like an amazing cpu for the price.i am going to use the reg atx mother boards.what size case should i put the intel I5 2500k in.mico,mid or full size case?
Engima
711
It depends on the physical form factor (size) of the motherboard but a mid-tower is a safe option to get unless you plan to build your computer and never move it in which case a full tower will do.
