Hi there,I just got this pc.
amd t1090 6core
power color radeon hd6850
8G ddr3
AsusM4n68T-m v2 mobo
Windows 7 64bit
now I am wondering if my power supply is good enough witch is a 500Watt I got with the case..
I had "i think" driver issues with my gfx card and still can't figure out why my card acts out after the catalyst and driver installation.they said the minimum power supply needed was a 500watt.
I can now buy this Proline 600W PSU, V2.2, 12cm Bottom Fan, Non PFC 180x140x86 20+4Pin Main, 1x 8Pin 12V, 5x Molex, 4x Sata, 1x 6Pin PCI-e but don't know if it will solf my gfx card problem.
amd t1090 6core
8G ddr3
Windows 7 64bit
