I am having a strange problem with my new build. For some reason when I try to start the computer it won't start. The MemOK will turn solid red and the monitor wont show anything. When I hit the MemOK button, it will flash slowly then quickly then turn solid again, but the monitor won't start.
The strange part: If I unplug the computer for about 20 seconds then plug it back in, the MemOK light will flash twice then it will start up ok. Once the computer is running, there are no problems. I have run multiple memory tests, a cpu stress test, and games. It all runs perfectly. Once I turn it off, though, it will go back to step 1, and I have to unplug it for 20 seconds.
I am thinking it is probably a motherboard problem, but before I send it back I wanted to know if anyone has experienced something like this / has any advice.
Specs:
AMD Phenom II 1100T
Corsair vengeance 8gb DDR3 1600
Asus M5A97
Sapphire 6950 2gb
Corsair 850watt PS
UPDATE:
The problem was a bad motherboard, as I suspected.
Specs:
AMD Phenom II 1100T
Asus M5A97
Sapphire 6950 2gb
Corsair 850watt PS
UPDATE:
