RAM detection problem
Last response: in Memory
Hi,
Last year I bought 3 x Zeppelin 1 GB DDR 400MHz Bulk RAM. My computer started having problems recently and I tested the RAM using Memtest 4.20. The RAM didn't pass the test. Having 3 sticks of RAM (I will name them stick 1, stick 2, stick 3), just one of them proved to be faulty. Even though it's faulty, stick 3 is working fine sometimes, so the problem is intermitent. After removing stick 3 (the faulty one), I have the following problem.
If I plug in stick 1 only, it shows 1 GB (alright).
If I plug in stick 2 only, it shows 1 GB (alright).
If I plug in stick 1 + stick 2 together, it shows 1 GB. (which is wrong! It should be 2 GB)
If I plug in stick 1 + stick 3 (the faulty one), it shows 2 GB. (alright)
If I plug in stick 2 + stick 3 (the faulty one), it shows 2 GB. (alright)
If I plug in stick 1 + stick 2 + stick 3, it shows 3 GB. (alright)
I have 3 slots in my mother board. I tried making all the possible combination, the problem is still there, so I am pretty sure it's not a matter of choosing the wrong slots.
It's not a Windows problem as the issue is present in Memtest 4.20.
My specs:
Motherboard: EP-8K9A7I
RAM: 3 x Zeppelin 1 GB DDR 400MHz Bulk
CPU: AMD Athlon XP 2500+
HDD: Maxtor 80GB
More about : ram detection problem
Related ressources
My guess is that your mobo might be malfunctioning or a bad ram stick. If thats the case you will need to buy a new mobo...and if you do that you should get a bit newer mobo ( atleast am2) and get yourself a duel core processor from amd for cheap. new mobo and processor will make skype work much better ;D. If it is a bad ram stick, look for the same model of ram and buy a gig module and swap out the bad stick.
Ask the community
