After around 6 months of use my Gigabyte mother board has failed on me with massive bluescreens and boot cycling.
So my question is what motherboard to replace it with. My setup is as follows
EVGA Superclocked 580gtx
i5 2500k
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
My past motherboard was this one http://www.newegg.com/Product/Product.aspx?Item=N82E16813128512
I mostly use this setup for gaming and other daily use.
I have heard good things about Asus boards and here are the few I was considering.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131820
Not sure what the advatage is of the z77 chipset over the z68?
Also what exactly is the Wifi-Go feature? is it a built in wireless adapter or a router type deal?
Let me know what you guys believeis best, or any other boards around the same price that you think are better?
Thanks
i5 2500k
Thanks
