SABERTOOTH Z77 FAN SPEED HELP
Hello, i just recently bought a SABERTOOTH Z77 for my system:
CORSAIR 600T
SABERTOOTH Z77
EVGA GTX 680
8GB RAM VENGEANCE
I5 3570K & CORSAIR H60
IS there any way to change the fans speeds on the SABERTOOTH FANS, not the case fans, not the CPU Cooler Fans, but those lil fans that come with the motherboard.
if so, how do i do it?
im trying to go with a quiet system at night so i disturb my family and those fans (at least for me) right now are lil bit annoying when the other PC case fans/cpu fans/gfhcs card fans are set to quiet, soo thanks any response would be appreciated :)
2 answers Last reply
More about sabertooth speed help
  1. I have that mb there under the monitor temp of the mb. pull the list down you see assist fan1 and assist fan 2.
    by default it set to auto and there running at 4000 rpm. set them to man and set the fan warning speed to 200.
    and on the last line (let them be turned off) default is no...set it to yes. save and exit and then reboot.
    the fans will now be off intill needed.
  2. 1. remove the fans
    2. use bios to set a lower speed
    3. use fan speed options in asus AI suite to set lower speed
    4. use a voltage lowering cable / fan controller (basically a resistor) to lower voltage & therefore speed. :D
Motherboards Sabertooth Corsair Fan Speed
