Go to 'Control Panel'click on 'All Control Panel Items'..then click on 'Display'then go to 'Adjust Resolution'....Depending on what kind of monitor you have you will want to make the resolution the 'Native Resolution'. Chances are it is either 1680x1050 or 1920x1080.Make sure after you pick the native resolution you hit the O.K. or 'Apply' in the lower right corner.If that does not work..on the front panel or side panel of your monitor..go into options and reset everything back to defaults.This should take care of the problem.If the 1st does not work,try the other and if still no luck let me know how things went...and I will get back as soon as I can....
