PC has power, but wont start
Ok, so heres an interesting dilemma.
I got up this morning at 5, checked the weather, and went to work. Got home at 3, and PC wont start. We DID get a major thunderstorm yesterday, but all peripherals and PC are plugged into a APC UPS.
So I believe that it is unrelated to the storm. I am running a Cougar 1000CM 1000W Power Supply with an ASUS P6TD deluxe motherboard
When I turn on the power supply, the 2 buttons inside the case, on the motherboard for power and reset, they are both lit. However, when pressing the power button (either on the case or on the motherboard) I got nothing. No fans, no beeps, no nothing. I disconnected all peripherals, and tried again........ nothing.
I disconnected all of the power cables except the motherboard that plug into the power supply......nothing.
I have not removed video card, HD's, CD/DVD drives, etc.
Thoughts on the culprit?
UPS: http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BX1300G&tab=models
Power Supply: http://www.hec-group.com.tw/retail_power_supply/cougar_1000cm/
Motherboard: http://www.asus.com/Motherboards/Intel_Socket_1366/P6TD_Deluxe/
Motherboard Buttons: http://images.bit-tech.net/content_images/2009/12/asus-p6td-deluxe-and-core-i7-overclocking/4.jpg
3 answers Last reply
More about power wont start
    Sounds like a bad motherboard to me. I had a very similar problem. In my case my CPU got fried as well. Hope you have better luck
    Disconnect the PSU from the system and jumper the green and any black wire on the 24 pin connector. See if the PSU starts with the switch in the on position.
  3. I just had a similar issue - try resetting CMOS - worked for me...
Asus Power Supplies Motherboards Power
