Possible Display/EVGA 570 Problem
Hello,Recently i hooked up 2 monitors to my gtx570.All was going well until i noticed when i move around programs they seem to leave marks on my screen as i move them around.Does anyone know what is causing this?For example when my taskbar goes hidden it leaves 4 lines as it is going down and all i need to do is move a program over it to make it go away.
Graphics card Master
This sounds like your graphics card is defective.
You need to test it in another system which has a PSU with sufficient 24V amperage for that card. I think it's 38Amps. Most 650W or higher PSU's should be sufficient.
If it's a dual-rail system the Amps will be shown as a combined value; you can check this information online, in the manual or on the PSU itself.
I'm about 95% sure it's a bad card.
You can also contact the company that sold you the card assuming it's still under Warranty. If it's under Warranty initiate an RMA or simply contact support and explain the problem, though I'm certain they'll tell you to return the card.
A less reliable test is to try a different graphics card. To do so:
1. Remove the video drivers (add/remove programs)
2. Shut off your PC
3. Switch graphics cards
4. Turn on your PC
5. Install the drivers for the new card
Ask the community
