Want some advice on my new build system
I wanna know your opinions about the system i build for Gaming. Overall i tryd to build the best gaming pc possible for the budget of € 900. I had to replace the MSI R6950 Twin Frozr III Power Edition/OC 2048 MB for the GTX 570 because the ati card hasnt been orderable for over a month and i think its a good replacement because i play @ 1680x1050 and the benchmarks look good of the GTX570.
I am gonna install windows 7 - 64 bit and wanne run all new games @ High Quality for a while...
G.Skill Ripjaws-X 4 GB, PC3-12800, 1600 MHz, 9, Non-ECC, Kit Of 2 - € 40,00
Sony AD-5260S-0B DVD/RW 24x SATA Dual Layer Black Bulk - € 17,99
Cooler Master CM 690 II Geen Voeding, Zwart - € 68,00
Cooler Master Hyper 212 Plus - € 28,98
Samsung Spinpoint F3 1 TB, 7200 Rpm, 32 MB, Bulk - € 46,99
Intel Core I5 2500K 3.33 GHz, Boxed, Incl. Videochip, Quad Core € 185,99
XFX Core Edition Pro 650 Watt, 20+24 Pins - € 74,99
Asrock P67 EXTREME4 (B3) - € 131,00
EVGA GeForce GTX 570 SuperClocked 1280 MB € 298
2 answers Last reply
More about want advice build system
  1. Very nice build. I think you should go with the 6950 though, you should have no trouble maxing out games at that resolution with the 6950. Plus if you get a better monitor and another 6950, they scale better than 570's. But both are still very good cards
  2. I second that. Your build is quite nice and shouldn't need anything more. Both the 570 and the 6950 are good cards, but if you can't get your hands on the 6950 I don't think it's worth the wait, the 570 will do a fine job. You'll be able to max out your games without a problem.
New Build New Build Systems
