What power supply should I get for my computer?
It's a lenovo m58p mini slim one. I need to a better power supply since right now it is 280 watt. I don't know which one to get but I need a 300 or 400 watt one that's cheap and good quality that fits in my 3 1/2 inch computer case. And if I do get one, do I need to change my motherboard or other components? Or will it not matter
2 answers Last reply
More about what power supply computer
  1. You won't find anything much higher than 280 watts. I recommend a bigger case that can use a regular atx power supply if gaming is what you want to do. Then you will also have room for a regular video card. Your system wasn't designed for gaming.
  2. And, why did you want to change your PSU? Is it faulty or you want some gaming?
Power Supplies Computers Components
