First Build - Sub $1000 machine
Last response: in Systems
Hello,
I am seeking the community's take on my first build, a machine I will use for photo editing, some gaming (Civ V, and the like), and music storage and playback.
Any thoughts, suggestions and comments are welcome. Any glaring compatibility problems would be appreciated!
Here's the build:
Cooler Master Storm Scout SGC-2000-KKN1-GP; ATX Mid Tower Case
Antec High Current Gamer Series HCG-750 750W ATX12V v.2.3 SLI/Crossfire Certified, 80 Plus Bronze
Gigabyte GA-990XA-UD3 AM3+ AMD 990X SATA 6B/s USB 3.0 ATX AMD
AMD Phenom II X6 1100 T Black Edition Thuban 3.3GHz, 3.7GHz Turbo Socket AM3 125 W Six-Core Desktop Processor
G.Skill Ripjaws Series 16GB (4 X 4GB) 240-Pin DDR3 SDRAM DDR3 1600
EVGA SuperClocked 01g-P3-1367-TR GeForce GTX 460 SE (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 X16 HDCP Ready
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM SATA 6.0GB/s
LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 Lightscribe Support
Windows 7 Pro, OEM, 64 bit
I have an existing, identical WD HDD which I will be using as a backup in my new machine.
Thanks.
More about : build 1000 machine
windows 7 64 bit -100 newegg
1.5 TB HD http://www.newegg.com/Product/Product.aspx?Item=N82E168... 65
msi mobo +i5 http://www.newegg.com/Product/ComboDealDetails.aspx?Ite... 365 (20MIR)
2 kits of ram http://www.newegg.com/Product/Product.aspx?Item=N82E168... 120
dvd burner http://www.newegg.com/Product/Product.aspx?Item=N82E168... 20
gtx 460 http://www.newegg.com/Product/Product.aspx?Item=N82E168... 160 (30 MIR)
case http://www.newegg.com/Product/Product.aspx?Item=N82E168... 80 (10MIR)
910 before shipping and rebates.
EDIT forgot psu lol
antec 520W psu http://www.newegg.com/Product/Product.aspx?Item=N82E168... 70
also you probably only need 8 gb of ram
the caviar black puts me a small amount over the 1k. +25
so total 980,
1005 with WD HD
Thanks for response. Do you see any compatibility issues with my build?
For what it's worth, here's what I paid for things, all from newegg:
Antec 750 W PSU, $89.99
GSkill 4Gb X 4 memory, $99.99
WD Caviar Black, 1 TB, $74.99
Gigabyte MB, GA-990XA-UD3, $139.99
Lite-On DVD Burner, $24.99
EVGA VGA GTX 460 SE R, $129.99
AMD Phenom II X6 1100T 3.3G CPU, $194.99 (only thing not on sale)
Cooler Master Case, Storm Scout, $79.99
MS Win 7 Pro, 64 Bit, OEM, $139.99
Total build: $974.91
sorry thought you were asking for advice on a build. um sometimes some mobos are having rouble with all the ram slots full and I dont like the se version of the gtx 460 but it all looks compatable. I would assume that the ram is ddr3 dual channel.
Straight from the website:
G.SKILL
Ripjaws Series
F3-12800CL9Q-16GBRL
240-Pin DDR3 SDRAM
DDR3 1600 (PC3 12800)
Quad Channel Kit
Thanks for your comments. May come to regret the SE.
Civ V is the biggest game I run on current machine, and am just limping along on 9800GT, Pentium D. Hopefully this build will be a big upgrade. Would kinda like to try Shogun 2.
What do you think? Send back unopened GTX 460 SE and upgrade?
Ask the community
