ACER ASPIRE 5251 BATTERY PROBLEM
i have Acer aspire 5251 laptop, initially the battery on it before was bad so i bought a new battery tested and working so if i plug in charger and switch it on it will indicate that the battery is fully charge but when i disconnect the charger from power, immediately the laptop goes off as if there is no battery in it, what can i do. does that mean the problem is from the motherboard?
3 answers Last reply
More about acer aspire 5251 battery problem
  1. Check and make sure all the battery contacts are there and in good condition otherwise its likely tha laptop has a daughter board which handles the power that needs to be looked at or replaced. This is often callled the power board or dc-dc controller.
  2. alright thanks i will check that and reply you
  3. it still doesn't work tired
CPUs Battery Aspire Acer
