G
Guest
Guest
I bought 256MB of new memory for my Gateway PIII-500 but am having some wierd problems and was hoping someone could help me out.
Original memory: 1 128MB module - PC-100 by Micron
New memory 2 128MB modules - PC-100 by MTech
Problem:
With all 3 modules in (any order) I get memory errors from not booting to just not running all apps. When I did get it to boot I ran Symantec's HW diag and it reports errors at 264110080.
With 1 old and 1 new module in (in any order) the machines works fine, no errors with Symantec, just normal. This applies no matter what order I have the memory in the 3 memory slots.
With 2 new modules in the machine works fine as long as the modules are in slot 0 and 1 on the motherboard. If I put one module in slot 2 and the other in either 1 or 2 the machine fails to boot.
With 1 module in any slot the machine works fine. It can be any one of the 3 modules.
So what I know so far is that all the modules are ok, the slots seem to be ok, but certain combos of the memory fail. I checked the Motherboard reference at gateway and I've met all the requirements for what type of memory and being able to mix memory types so I'm a little stuck.
Motherboard reference is at http://www.gateway.com/support/techdocs/references/motherboard/4w4sb0x0/4w4sb0x0.shtml
Can anyone offer any suggestions on this or am I stuck using 256MB of RAM?
Problem:
