Yes No
Ads
[Solved] Dir 655 problems
Forum Wireless Networking : Setup, Configuration & Security [Solved] Dir 655 problems
Best answer from emerald.
Hello,
when trying to install router to
at&t dsl modem cannot connect to
internet.following directions for
quick setup,it has me power dsl
modem down and move ethernet cable
from modem to router,power up router and wait.this part seems to work as i get a router config
complete prompt.the next step is
to connect ethernet cable between
router and modem and power up
modem .the dsl modem never shows
internet light.router also does
not display internet connection.
if i the same steps without powering down modem then router
and modem both display internet
connection,and my windows pc even
displays that i have internet
connection.but i get an error cant connect to internet display.
i can log in to router with no
problem
Reply to randyhill
what DSL modem do you have and does it have an IP listed on the bottom side?
what router are you using?
Reply to emerald
its a speedstream 5100 by effecient networks.
ip address is 192.168..0.1
Reply to randyhill
Best answer
disconnect the router from the modem.
log into your router
change the LAN IP from 192.168.0.1 to 192.168.1.1
save the changes
re-connect to the modem
Reply to emerald
Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > [Solved] Dir 655 problems
There are 2455 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
2 routers on one cable modem
By Routersforhumans, 2 days ago:
Hi Ryanht2, Check out these steps: How to Connect One Router to Another For this...
Best offers
Top experts
